Just installed a PCiii from an 03-06 RR on my 2007 RR. Everything hooked up fine, starts fine, and runs smooth. But Im getting the Fi light while the bike is running. It doesnt flash, just stays lit.
Also, can you custom make your own PC map on the website? They dont have an option to what I installed today (BMC filter) and stock pipe.
Have yet to adjust the setting on the PCiii and put a map on it, Im a little nervous having the bike run while im suppose to adjust it.
Anyone run into this problem before? Thanks!
With a stock exhaust you are not going to get too much out of the PCIII. Make sure all of your plugs are connected, something probably not plugged in, this why your FI is on.. T
