I’ve been having issues with my coolant, no overheating just the reservoir bottle filling up and not getting drawn back into the bike. Anyways here are the pictures, oil had 2.5k miles so I’m not sure if it’s just old or blown head gasket
Road surface Asphalt Manhole cover Automotive tire Circle
Liquid Water Cookware and bakeware Recipe Dish
note: I also did a test with a combustion leak detector where I put it on the radiator cap hole, the fluid was supposed to turn yellowif there was a blown head gasket but it stayed blue
BUT afterwards I drained my coolant and mixed it with the oil and the oil kept the same texture and color, so I’m not sure pls help
That's milkshake foam alright...
You can usually check under oil-filler cap without needing to drain.
Do compression-test!
Reactions: tary preisser
Discussion Starter · #6 ·
Hey Danny I’m back with results, I did a compression test and my numbers were
110
115
116
109
I did the wide open throttle and let the needle run up till it stops itself.
These numbers look normal??? Please help
