WHY would you do that?!
Seriously, are you stuck somewhere? Or are you back home? Drag that thing back home and get a multimeter so you can sort out the wiring.
ITMT, Try holding the throttle wide open and crank it. Try using some starter fluid if that doesn't work. If the fuel pump is priming then the safety circuit is a moot point right now. Unless you hit the Start/Stop engine switch.
