I have a 04 600rr, Im not getting fire to the plugs, but also my fuel pump isn't working either, I am not getting and power the the fuel cut relay any advice would be great
Have you done any mods to your bike? Wrecked etc, or it just stopped working? T
no mods, never wrecked, my fuel pump went out and then started working again the now the ignition stoped no spark as well as the fuel pump
Fuel pump bad maybe or your diode under your ignition went out. If you have a meter you can check power at the fuel pump, should be 9volts. This should get you close to the where the problem is. T
