1 - 3 of 3 Posts
Hey 600rr! First post on this forum, but I've been reading/searching a ton on anything that I've been wondering about. BUT, there is one issue that I can't seem to figure out.
Recently purchased a 2003 Honda CBR600RR(first time rider) and it came with a "hightechspeed" rear LED tail light installed that has the brake light and signal all built into one. Problem is that the rear turn signals don't work and I've been searching a ton and haven't found anything to point me in the right direction. I know this system is kinda old, but if it works fine, I'd like to use it. Can anyone give me a tip on how to do this? Thanks a ton in advance:) I really want to ride soon and won't do so until they're working.
BOTM Winner 03/13
Welcome!
When you say the rear turn signals don't work, do they:
A. Not light up at all;
B. Light up but but don't flash; OR
C. Flash too fast?
What wires do you have and where do they connect to?
Do you have a relay for the LEDs?
Got it! Took off my rear cowl(was scared as hell of it cracking), and found the wiring harness for the signal..hooked it up to the only two wires that weren't connected on the HTS unit and it worked out! I just left the green ground wires alone and taped the ends. Thanks anyways y'all! There will DEF be more questions in the future:)
1 - 3 of 3 Posts
