1 - 11 of 11 Posts
Twice now my 05RR has popped out of gear and basically hit a false neutral between higher gears (3-4 and 4-5). I do not run full synthetic. I'm using Spectro Golden-4 semi-syn. The bike has 18,000 kms and there really shouldn't be a problem with the clutch. Maybe the bike was a bit cold and I was too hot on the gas? Maybe I'll give it an oil change this week and see if there are any shavings.
Any suggestions?
Won't be anything to do with the clutch.
If it's jumping out of gear when you're accelerating it will most likely be worn gear engagement dogs, selector forks possibly selector drum. Engine strip down to fix if that's the case.
It's common to hear of this on earlier Gixer K models (maybe later ones too?) and some Fireblades pre 1000RR but not heard of many 600RR's needing geaboxes fixing.
commen YZF600 problem, never heard of it on a 600rr tho
Yea it doesn't stay out of gear either. It's a split-second thing and goes back into gear and drives fine. It has me a little worried.
i had the exact same happen to me a few times awhile back...changed my oil when
i noticed it. hasnt happened to me since then and its been over a year ago.
my oil was old and due to be changed. i dunno if thats what solved my issue. it hasnt done it since then.
but maybe for you...try changing the oil. its a cheaper way to find out before you get really technical with it.
like the what the guy said in the post above.
7086
It happened to me ONCE. Was cruising in 5th and then the RPMS started rising but I wasn't going anywhere, like slipping the clutch.
Just downshifted, and then got back into 5th.
Didn't wait to find out what would happen if I rode it out.
It may just be an oil thing, mine is black as sh!t right now in the window and it's only been 2K miles on Repsol 4T synthetic blend.
Rhino
Glad to read you are still around man you should stop by more often
Rhino
Thanks alot, Moe! I'm back and ready to roll. I was working 2 jobs and basically had no time for the net, but I'm down to one good job now so I have a little more time.lol. Good to hear from you buddy.
Thanks for the help guys. I'll change the oil. That'll likely fix it.
That is awesome man i am glad to hear you are doing alright
ha mine does it also
1 - 11 of 11 Posts
