1 - 3 of 3 Posts
Anyone have the GP Slip on from Dan Moto?
Been using it for a few weeks, but runs a bit rich so I am getting the PC 3 USB from a friend to set up, are they easy to fit?
Bike has a BMC Air filter fitted and New plugs with the Slip on and link pipe exhaust if it helps.
I assume from your signature picture that you're on an 03-06. It depends on what model of the PC3 you end up with. Some of the older ones require you to splice into the TPS wire, but newer ones have a plug to replace the splice. Regardless, you have to take off the fairings and more than likely the airbox. You'll end up tipping the gas tank back to get to the lower injector plugs. Either way, it isn't very hard.
1 - 3 of 3 Posts
