1 - 20 of 23 Posts
So I was installing a tune on my bike with a PCV but i have a two bros slip on...My problem is that i cannot find the right tune on Power Commanders site. they only have on for 07-08 Two bros slip on VALE with stock air cleaner.
Does anyone know if i should go with that even though mine is not a Vale two bros? whats my best option thanks guys
Your best option is to get a custom tune at a reputable shop. There are places online that sell custom maps based on your setup, which are a million times better than the maps on the Dynojet site and can be better than getting a tune on a dyno by someone who is not so competent.
Here you go: http://www.faic.cc/index3.html
You could also send dynarex (a member on here) a PM.
Thanks guys!
dynarex I tried getting onto your site but it wont let me on because it says its not finished haha
I got my map from dynojet and it works really well imo. What year is your bike and I can help you look for it.
Do you know anything about Sportbike Performance Center in Phoenix? I just sent in an inquiry at the FAIC place you posted in the link. Can't see exactly where they're located, but based on the phone number it looks like they're not too far away in Tucson(about 1.5hr ride). I got a quote for $250 from SPC and they're doing runs only for $30 so I figured it's worth a shot to at least see what it's putting out. I'm hoping the previous owner who put all the money into the PC5, BMC filter and Yoshimura RS-5 exhaust did something to tune it(either downloaded map or dyno tune) as I haven't had any complaints about the performance.
I'll PM dynarex as well so I can have as much info as possible on this.
Unfortunately I don't have any info on that center. When I needed a map, I went for the easiest way I could get one really and it was through dynarex. I haven't looked back since, I would only pursue an even better map if I'm racing but even for advanced track riding his map is definitely one of the best IMO.
Much appreciated
Did a dyno run today and it's just under 100 RWHP @12.5k and 45 RWTRQ @11.5k.
Gotta check my funds, but will probably be getting that map from dynarex later this week and go back next Mon to see what the gains are from a proper tune.
Mods are listed in my sig but are basically the Yosh RS-5 full exhaust and BMC high-flow filter... slip-on needs a repack and air filter was cleaned about 4k ago.
So I see these posts alot about our maps on the site are crap and I just don't get it. The maps on the site are tested at our facility to produce the best horsepower and drivability that we can for that bike, with that exhaust. It won't get any better than this. Granted not every bike is exactly the same but should be very close. We travel all over the country dynoing bikes and guys come up to the dyno with our base map that correlates to their setup and we rarely have to adjust it.
We have looked at some of these maps you can purchase "on-line" without the service ever seeing your bike, knowing state of tune, or knowing if it is currently running rich or lean and they have all been horrible. We had a local customer buy one of these maps and we ran it on the dyno back to back with our map and it was night and day. The customer originally stated the map he bought felt better until he saw the dyno runs, then he changed his story. Placebo effect? Not sure, but the AFR and power does not lie.
Do you have a comparison of those runs?
I'm curious as I just downloaded the map from your site for my setup:
16-001-009 2009-2012 Honda CBR600RR, Yoshimura RS-5 full exhaust, Stock or aftermarket air filter
Is elevation and temperature factored into this and is there a difference between stock/high-flow air filters or is it really just the exhaust that causes a difference in A/F ratio?
The problem you guys have is not what you provide or that your maps are inherently poor, it's that 95% of your customer base has almost no idea what the product actually does, what it actually changes and what to expect. And they think that once they install your $350 "magic box" they'll immediately see a 50% increase in power and are disappointed when they don't feel anything drastically different so they say your maps are crap, not knowing the bike actually runs smoother, cooler and throttle response changes are usually subtle when they expect this huge difference. Then because they read "your maps suck" posted by some random dude with no idea they think they need go buy one of these "special" guy maps to feel something and because those maps a lot of times drastically increase the fuel numbers right off idle they will feel a surge in "power" so they run around every place they can telling those that don't know any better that the $50 map was far better than a real tune from a real shop and your crap maps. And even if they feel nothing different or have no comparison with your provided maps, they still proclaim their worth because they don't want to feel ripped off that they bought basically the thing you guys offer for free.
Read around here a bit and see what people say and pass off as knowledge of your products (and it's the same on every forum I've been on); just the other day someone on here was eluding they thought your devices "flash" stock ECUs and EVERY thread about mapping starts and ends with dyno numbers and peak HP being the goal not caring about the throttle areas we ride in everyday.
I also think a lot of confusion also starts when they look online to see what you offer don't see a map for the EXACT same setup they have (say they have an Arrow SO and you guys only have Akra and TBR listed) so they think it's not going to work for them not knowing that in all honestly a slip on is a slip on and all the SO maps in the end will be pretty close and to just load the closest config and adjust from there if needed will work fine.
It's a no win situation at times for you guys but another factor is money: your guys' maps are what I would say are 90% perfect, but to get that final exact-to-your-bike tune is another $300 or so which no one wants to pay and a lot of dyno shops are shady anyway so when someone with apparently more knowledge than them offers a low cost "map" solution, well, an industry is created.
And your company is caught in the middle.
Mike
Mike
agreed that their maps are great on a dyno-but do you ride on a dyno
just as another opinion I would like for you to try a map that I made against your best map- around a track and in the street- and see how it compares-Ide be willing to bet its the same or better
no charge no obligation no harm no foul no animosity nothing
just a simple try it
your sig says youre ama so I would really value your opinion on this
Dustin Dominguez's maps, Danny Eslicks maps and most of the others that have won DSB and Supersport were also made on our dyno in the exact same way we make all of our maps. They did pretty good with our "dyno maps".
1 - 20 of 23 Posts
