would i benefit with this? all stock except for: proton signals, puig screen, hids 8k & 4 inch tank pad.
i feel like my cbr bogs below 4krpms
It can definitely help smooth throttle response and fixing A/F for your location, altitude, etc. can give you more power across the entire RPM range. It won't help make more power.
yes, i feel like my cbr needs a custom tune to smooth the powerband a little
everytime i go to fill up the tank, i add a 1/3 of a bottle of lucas fuel injector cleaner and it runs smmoother!:) im hoping maybe with a tune it will always run smooth without addittives..
the bike idles fine and only has 2200 miles :)
thanks for your input bro
BOTM Winner 1/13
neh, if your thinking about buying them NO, stick to the stock map, they are good . but if you do get the PCV. then it will only be good at its full potential if IF you get it DYno right
Look in the diy section. Do the intake mod. (gutting all the restriction in the intake) should open it up alittle in that rpm range.
