I don't have a CBR600rr. It's a 2001 CBR600F4i that I purchased a year ago and finally got to replace parts on it so that I can enjoy the darned thing. Before the Power Commander V install, it ran smooth, revved up really nice and had exceptional power even though i found out recently that bikes from the factory are tuned lean on fuel for emissions and since I replaced the stock muffler with a short Coffman's slip on... story short, I wanted more get up and go to resolve the lean issue post muffler install and I decided to get a commander. My brother's Suzuki Hayabusa has one and it ran pretty well, so I opted for the brand he has on his. A Dynojet power Commander V.
I ordered it, downloaded the software to be able to transfer a fuel map from their site and all seemed ok. It was simple enough and I thought it went pretty smooth.
First, I noticed, that from a cold start, it wouldn't idle up as it did before the commander. I let it warm up to see if it would do something out of the ordinary and it didn't until I decided to rev it up a little... it stalled instantly. I turned it back on and it idled ok but the fault light flashed 8 times. It was a throttle position sensor code. I disconnected the commander and plugged the stock connectors again and the bike ran ok and it even revved up with no code flashes to speak about. I emailed Dynojet and explained to them what I did and what I figured out and their excuse was that I messed with the TPS when I know I didn't because the kit only has two connectors that go inline with the stock harness connectors that run along side the left side of the bike right behind the VIN label on the frame... and then there was the ground eyelet connector that went on the battery. The TPS is directly under the air filter box, so... i couldn't have touched it, as I explained to the rep I was speaking to from Dynojet. I double checked every thing. They were of no help as they continued to suggest I did some thing wrong.
If it runs and revs with out the Commander and doesn't rev with it... it's the commander. maybe it's a software issue? I'm curious to know if any one has had a similar concern with this product after they've installed it. I would like to know how to resolve it.
