Getting a violent cut in power under heavy load.
Throttle completely cuts out around 6-7 rpm when there is more than 50% throttle applied. Throttle gets choppy and won't accelerate past said rpm.
-revs to high rpm fine in neutral
-no problems with freeway cruising around 8-9k (with light throttle application)
- no check engine lights
-battery just fully charged
08 600rr 19k miles
-power commander V
-Annitori quickshifter
-Full exhaust
-valves never adjusted
-original spark plugs
:ponder:
Any input is greatly appreciated
Cheers!
Maybe your throttle is just tired?
... I got nothing
Got around to unplugging the quickshifter and that has solved the problem.
She's back to running like a raped ape.
Thanks wibbly!
