1 - 3 of 3 Posts
hey guys,
im installing a new gear indicator and a few tech issues,
One what cable can i use for the power, so it goes on from key ignition only, i used a black red cable in the (grey) cluster green solid for the (negative) (blue) cluster green and yellow cable for the tacho/revs (blue) cluster.
When i mention cluster its the cable cluster under the left air duct cover if that helps.
Im sure i have it right but not 100% with the (+) side of things, and if it can stuff up the G.I
As im having issues with the G.I as it wont reset its a biketronix G.I, and thus wont learn the gears either, but i gathered if i have the power part right, then it must be another issue/problem.
thanks
ooh btw, how do you remove the pins from the cluster packs (grey/blue) i could open up the blue cluster but they grey one wouldnt open up, and as for opening it up its just the side that opens, but yet i cant get the pins out still, i just soldered it through the side wall.
CBR 600RR 2005
Hook it to the third eye. Key power only.
thanks for that, i forgot about the most simple one
1 - 3 of 3 Posts
