1 - 20 of 59 Posts
hey guys it has been a long time since i visited this message board, after few month looking for 600rr i found one and i bought it. it is 2005 cbr600rr. i am very happy with it.i can not belive how light it is compar to my 1999 hayabusa.
now to the important part, i am preparing the bike for the track and i have done the following mod
race body work
vortex rear set
vortex gas cap
keyless entry
safety wire the whole bike
took off the kick stand the headlight switch
powercoated the wheels neon and race take off
took off the exhaust heatshields
new brake lines on the front
vortex upper bracket
i think that is it for now, what else should i do, i am running out of money and i just want to see if there is any cheap mod to do. i am not looking for more power so exhaust is the last thing i want to do.. i can not afford a shock so i am going have to life with the stock one for now, and forks i might do by the end of the season.
if there is anything else i should do please let me know.
thanks
Superbike racer
when you do the suspension do the shock and the forks at the same time. your suspension works together....
steering damper
safety wire header bolts if racing, but not required by most track day organizations
were can i find the safety wire requirement. do i have to do the calipers forks levers??? i am going to the headers bolts today.
You need to go to the website of the trackday organization(s) whose events you are thinking of attending, and look up their specific requirements. Usually it's just a safe, working bike; no glycol antifreeze (see below), and tires with sufficient tread/life. And the appropriate safety gear of course.
As BigTuna said, most orgs do not require wiring the header bolts.
Yes, you should run distilled water (or water + Water Wetter) instead of glycol-based antifreeze, even if the org does not explicitly require it. (But most do require it. Antifreeze is a b!tch to clean up if you go down on the track.)
Hey...what kind of race plastic did you wind up putting on your bike? I'm looking to get a set and am trying to narrow it down.
Thanks!
Thanks!
Armour bodies and Sharkskinz..
sami600rr, the stock shock is good. it's just a matter of getting the correct spring for your weight. If you're around 135 - 155lbs., your'e good to go. But definitely upgrading suspension always helps.
Find the minimum requirements for the track day organization if you're just doing track days. If you start racing, then that's the time to start safety wiring. Be prepared too, such a pain. There are some sticky threads I started for some help guides that a bunch of people from here contributed to. Great info. If you have any additional questions, just post or PM me and hopefully I can help.
Good luck.
Good luck.
what if you weigh 175 and thats not including the gear?
WERA does not require you to saftey wire the header bolts. If I were you I would wire the main things even if it is not required. Things like brake calipers, drain plugs, rear axle nut. These things have a bad habit of coming loose on the track. Lock tight is good to use on things that can't be wired.
Use Water Wetter or Engine Ice , available at all bike shops. Don't use antifreeze.
Antifreeze won't evaporate and can become a slippery debris if its on the race line, very dangerous.
Track Days, don't need to safety wire, but it doesn't hurt. Just make sure your Oil Plug won't fall out on a session, not the best way to get popular.
After a few Track Days, you'll have noticed what the other riders have, but remember this.
When ya get about 500 bucks, get your stock suspension upgraded. I just did mine. And I'll be getting a good 10-15 seconds off my laptimes.
I used Racing Performance Services
http://www.roadracinghelp.com/
yeah, then definitely stiffer springs will be needed so they don't bottom out on hard braking or hitting bumps mid-corner. There are several companies that replace springs and do valve work for about $300 each end, front and back. I would save up money and invest in that as poorly set up suspension will make for a terrible feeling ride.
Well, I was thinking of going with Thermosman, but I have been advised to hold off on it. I get my bike adjusted for each track and it has felt smooth. Hopefully sometime soon, I will upgrade the suspension. Do you suggest replacing the springs or the whole internals in the fork?
hey guys thanks for the help, i am going to set up the stock shock and forks to my weight. also i am going to get ice engine . i also have drilled all the required bolts (forks. calipers oil cap and filter , front and rear axel , front and rear calipers, front forks,front master cylinder.)- i still need to do the header bolts but i am not sure how to do it, do i drill the nut or is it some where else. let me know
Hey papo600rr,
It's tough to say that you "need" something changed but here was my scenario...I rode from May 2005 to December 2005 without changing my stock suspension, I just adjusted sag as much as I could so front wouldn't bottom and rear had a good range. I don't know what the range on the rear was, suspension tuners would do it at the track for $20. The tuners also adjusted compression and rebound based on my feedback.
I rode strong and comfortably for those 8 months. A suspension tuner suggested though that I get my forks revalved because when he pushed on the front, it sounded and felt strange to him, like he knew the oil inside the forks were old.
So even though it felt really good to me, I wanted to see the difference, and I've read in 20 million places that upgrading suspenion is key and just watching motorcycle races you noticed everyone talks and/or complains about suspenion setup, pretty much making or breaking their lap times. So I revalved the front and went ahead and got the correct springs for my weight. I wanted to learn more about adjusting the suspenion myself so I also invested in a rear shock that I can tweak based on articles I've read.
Results: I have to say the bike feels WAY better. Pretty much night and day. My bike absorbs bumps more, and feels more solid and planted. This is a big step in turning faster lap times because I'm more confident in my motorcycle and don't have to worry about bumps mid-corner. It's true what suspension tuners say that you really don't know what you're riding on until you've tried something different. In any case though, you still have to adjust your suspension for different tracks but overall, upgrading suspension gives you a better range for adjusting and potentially smoother curves. I'm still learning, but this was my experience.
Sorry such a long explanation :)
I'm not sure what year your bike is but on my 2005, I'm actually trying to do my header bolts right now (They are actually nuts since they have a hole in the middle). The nuts toward the front of the bike, I'm trying to take off each one and drilling a whole straight through one flat side at the very opening of the nut, still leaving some metal left so I can thread safety wire through.
The nuts on the headers toward the rear of the bike I'm having trouble taking off. I want to be able to torque them back to 9 ft.lbs., but my adapter won't fit since the headers taper toward the middle. I'm still trying to figure it out but I may just hand tighten with an extra little turn to make it snug and just safety wire the bolt.
I would go with thermosman, i have a frontend built buy him and it is awesome. As for sami600rr i would have taken the money spent on powder coated wheels and vortex gas cap and put it into an exhaust, power commander, air filter suspension(front or rear), Steel braided lines, 520 conversion, aftermarket brake pads, steering dampner, you could use all kinds of stuff other than the kewl looking wheels and gas cap!!! How much better is your bike going to handle or run with mods like that, its a waste of money especially if your on a budget.
Discussion Starter #20
they all came for free with the bike so i could not say no to it. i just did the safety wire, and installed everything. i would not spend anymoney of the exhaust any time soon. for the next year i am going to spend my money on track/race days and tires and after this season i am going to update the forks and shock. my last mod is the exhaust.
thanks
1 - 20 of 59 Posts
