1 - 8 of 8 Posts
Just finished filling and fairing the bodywork for my track bike... I'm gonna take it in to a local paint shop and want to have the prep done... so Question: How fine do I sand? 80? 100? 150? 220?
Thanks in advance!
I use a 350 to take the old stuff off, then put a coat of primer on. After that first layer of primer I wetsand 800. I then put on my first color coat, and wetsand with 1500, then the second and third coats go on. After they dry about 4 coats of clear makes its nice and shiney.
ok, but i'm not painting it, i'm giving it to an automotive paint shop... what will THEY need... keep in mind it's a track bike; Good From Far and Far From Good is what i'm after, i just want it sanded so the paint sticks...
use the 350 then, they'll take care of the rest. And give it a good mineral oil or aceton bath to get all the grease and dust off....
350? yikes! i guess the automotive stuff must be really thin paint... when i paint my boat they don't want you to go any finer than 150 or you won't have enough mechanical grip for the paint to stick!
what condition are the parts in? ... if you repaired any spots...I'd throw a good layer of primer on there and then wet sand it down with 400.....if there isn't any repairs... you can either sand with 400 or 600...or lightly scuff it with a 3m scotchbite pad
well, it all depends on if your scuffing it up, or taking the layers of paint/dye off the part. I"ve painted dozens of pcs and 350 has given me the best results.
1 - 8 of 8 Posts
