1 - 2 of 2 Posts
Hi i am from Perú,
dont speak english very good but i hope you can understand...
A while ago my motorcycle had a problem,
one day was on the road and started out white smoke from the exhaust pipe, I stop and waited and was also throwing oil.
i wonder if anyone is ah been the same problem and how could solve this.
that day i change oil and filter.
i would like review or change the valve seals
if have some video or tutorial to check that
my motorcycle:
Cbr600rr 08
20 000 kilometers
tha last time when i change the oil was consumed.
White smoke usually indicates a coolant leak somewhere. If your oil is being consumed then obviously it is also leaking from somewhere and into the cylinders which usually gives off blue/gray smoke.
Take it a shop you trust so they can inspect it thoroughly for you.
1 - 2 of 2 Posts
