You need to connect both Hid Ballasts to the low beam side of wiring. This will keep both on all the time when the bike is on. Then both solenoids will connect to the factory hi beam side of the wiring, that way, when the high beam is switch is activated, both solenoids activate and both projectors switch to a "high beam".
