1 - 10 of 10 Posts
Hey guys,
I just picked up a cbr600rr from a friend. He hasn't taken it out for about a year. So my question is, what type of maintenance should I get done? I was going to get the oil changed, a brake fluid flush, coolant, and clean/tighten the chain, and clean the sprocket. Anything else I should get done?
^ +1 maybe check the tires for dry rot? idk your list sounds pretty complete
Put some pilot powers (tires) on there, check to see if the battery is good and buy a battery tender, check the rotors and pads.
You'll want to drain any old gas out of the tank, put some fresh gas in. Maybe some injector cleaner because the old gas can gum up the lines if it stays in there for a while.
I believe they have said it all but to add check the tire for its expiration date just to be safe you don't want to ride with a expired tire.
1 - 10 of 10 Posts
