1 - 20 of 21 Posts
I just got mine and put the bike up on it for the winter. Problem is, seems my bike leans to the right when on the stand. Anyone else?
Yes me RC51 does that with the pitbull rear stand. I never figured out if the spool bosses on the swingarm aren't welded at the same height or if the stand is slightly off. I wouldn't worry about it, mine is rock solid anyways.
N
Leans to the right? Really? Mine doesn't do that. So long as it's resting on the stand you should be fine.
yep! mine does the same. its pretty stable though.
Mine doesnt do it.
smwilli said:
heres a pic. you can kinda tell thats it's leaning. It's not the cement. I alredy took a level to it to check it.
Mine doesn't lean.
from your pic. you can hardly notice it. as long as it's stable i wouldn't worry about it.
I just grabbed a tape measure and went from the level floor to the centre of each spool. It is just under a 1/4 inch difference and the bike leans to the right. Really its nothing, and it is rock solid when you push on the bike side to side.
I wouldn't be busting Pit Bulls chops over something small like that. The stands are beautiful and the lift stands that go under the pegs are especially nice.
No idea, if it was something important I would investigate further. Its the kind of thing where only the mentally disturbed Honda owners would notice who have to make sure everything is absolutely perfect.
1 - 20 of 21 Posts
