You can do them, it shouldnt be effortless though. You should feel a decent amount of resistance especially when downshifting. Clutchless downshifts are a not a good thing to be doing though.
I agree, even the manufacturer says to use a clutch when downshiftingYou can do them, it shouldnt be effortless though. You should feel a decent amount of resistance especially when downshifting. Clutchless downshifts are a not a good thing to be doing though.
:+1: you can do them.You can do them, it shouldnt be effortless though. You should feel a decent amount of resistance especially when downshifting. Clutchless downshifts are a not a good thing to be doing though.
I think its more referring to the safety aspects of it. With our bike not having a slipper clutch the average nub shouldnt be racheting down 3 gears while pegging the throttle.:+1: you can do them.
but really slim how so, i always thought it was ok to do clutchless downshifts, since to me i thought you would do the same harm, if any, doing clutchless upshifts.
It's a LOT harder to match the rpm so there is a much higher chance of damaging the dogs. It can be done though, just takes a lot of practice and good timing of the throttle and shift.I think its more referring to the safety aspects of it. With our bike not having a slipper clutch the average nub shouldnt be racheting down 3 gears while pegging the throttle.
Im with you though, i dont suspect going down could do any more mechanical damage than going up, though i am no engineer...or mechanic.
Thanks, that's what I was hoping to hear as well. (if you were referring to the downshifts)Its fine, if the transition is smooth there is nothing wrong with doing it and not a hugely uncommon technique to use... the issue is getting the rpm right to make it smooth.
