ET AL - Please advise:
1. Does this model have an integrated brake system: I. E. - application of the rear brake pedal supplying 30% of braking action to one of the front caliper/rotors with 70% being applied to the rear brake system?
2. The owner's manual advises that the totaling passenger load weight rating as 397 lbs? It didn't give a motorcycle weight rating, but I read elsewhere that its (dry?) weight is 370 lbs. Could this be accurate? Two rider's weighing an average of almost 200 lbs each on a 370 pound motorcycle? Are the stock tires rated for a load (GVWR) of almost 770 lbs when the machine is capable of speeds of 150mph?
3. If one of the 55w headlight bulbs burns out, will it automatically switch to the other bulb? (I had a 1979 Yamaha XS 1100 that had that feature - if low beam burned out, it would automatically switch to high beam or vice/versa).
4. Does the "Passing Light Switch control (on the left handlebar) cause the headlights to pulsate or does it have to be depressed and released by the operator to cause that sensation?
5. what could one generally expect (performance wise) by installing a $600.00 (in 2005 dollars) Yoshi pipe on this model? Would it have to be mapped to obtain an appreciable increase in power?
I'm trying to acquire this info for interested friends.
Thanks for you time.
Dave Freeman
Dave Freeman
