WCR Racer
I just got back from testing out my new bike and I put a quickshifter onto the bike. Everything with the shifter and install is properly done.
But my issue is at high RPM's I cannot feel the shifter working properly. Mostly because I think the shower injectors are kicked in.
I looked up some info on DynoJet.com and only found they suggest an Ignition Module installed to cut power for quicker shifts.
As good an idea as this is, I am not looking to spend $$$ any more than I have all ready.
Who has had to deal with this or has suggestions?
Should I lengthen cut out time through PCIII programer?
yeah, thats the problem with the 600rr. I had to run the ignition module. I don't think lengthening the delay time will help any because the shower injectors are still on. It does work flawlessly with the ignition module.......good luck
