1 - 1 of 1 Posts
R&G engine covers
Just got these in and not loving the clutch side. Where the cover touches the clutch cable adjuster is no bueno. Once the cover is in place the bracket for the cable adjuster is not allowed to seat correctly and is loose.
Anybody have this problem?
Edit:
I ended up tightening the screws down more and it pulled the bracket flush and seated correctly.
I guess I was hesitant to over tighten as the instructions are very clear on not over tightening. The grommets are all plastic and would split.
Hind sight, why doesn't R&G use metal grommets like GB does?
1 - 1 of 1 Posts
