1 - 11 of 11 Posts
i heard that you run 30 psi in the front, and 22 psi in the rear of race tires, is this true? if so, thats insane
Ok, I am using Pilot Race Mediums for Willow Springs in a few weeks. 22 psi in the rear and 30 front? Is that what I am reading? Why not 28/28?!
28front/22rear - dont really know why tho but if you try 28/28 vs 28/22 - you'll feel the difference...
30/22 is what I start with in TX for the cooler months. 28/22 summer. I believe the lower pressures keep the tires hotter and your contact patch in optimum shape. I also pay very close attention to pressures when hot, and prefer a 3-4 psi expantion. I have found from MY experience that is where I get the best feel from the tire. I would suggest you experiement for yourself and feel the confidence you get with the power race.
N
22 sounds really low. Can you tell a difference between 25 and 22 psi in the rear?
1 - 11 of 11 Posts
