1 - 3 of 3 Posts
Ive tested the voltages coming into the relay and all seems well..+12/-12 where i guess it needs to be. For some reason the fan is still not kicking on..should I get a new relay?
I had that same problem. I unbolted my fan from the radiator to examine it and I discovered there was a pebble wedged in the fan blades preventing it from turning. Once I removed the pebble my fan kicked right on. Another way to check your fan relay circuit is to swap it with your headlight relay circut. They are the same type of relays. Don't forget to check your fan fuse as well.
1 - 3 of 3 Posts
