Last night I geared my 07 and had to pull two coolant lines. I lost some fluid and was wondering what fluid I should use? It was green but I've never put anything except water wetter in a bike.
honda radiator fluid if you are just topping off.
it is green
i drained my fluid to remove the radiator once and refilled with GM dexcool.AL safe fluid
Use the same color fluid if its Green you should refill it with Green
regular radiator fluid will do the trick and its the same stuff any way
Id suggest draining your whole system and flushing it, then refill with ENGINE ICE...your bike will love you. Only costs 20 bucks per/gal and its great stuff.
