Tell the dumbass that caused it you will be sending him a bill from the guy that corrects it.tigerboy211 said:what happens if there is motor oil in your coolant chamber?
Sounds like a blown head gasket....i have motor oil in my radiator and i did a radiator flush with hot distilled water. i poured two gallons of boiling waters through followed by two gallons of room temp distilled water. yet there is still a little bit left. i was wondering if i should use any type of radiator cleaner? like the ones for cars?
STUNT 101 said:For those with Engine Ice...is it worth it? Do you have to drain and fill more often when running that stuff?
Why won't they let you run Engine Ice on the tack?cbr 600rr az said:I talked to a lot of guys running Engine Ice. All said it makes a difference worth the effort. Some said the results were amazing, some said just a bit better.
Once a year is all you should need to flush unless you run a lot of track days. The local track just announced you can't run Engine Ice on the track anymore. Great. That was half the reason I wanted to change out the coolant.
I waited until it was time to change the coolant, it takes a little longer to get hot and cools faster once you get moving. Rain today so I did not get a chance to go on a long run. I am hoping for lower operating temps. I'll let you know my results.
In AZ with the heat, I was just looking for an edge against the high temps.
