1 - 9 of 9 Posts
well i'm fixing alot of broken sh*t on my bike, and my radiator/fan assembly is one of them.
I took off my old radiator a while ago, put the bolts somewhere .. and the new radiator came in today.
What is my problem? either i can't find them or am not sure which ones they are out of a mess of bolts.
does anyone have pics of what they look like by chance, or can they desrcribe them? I looked at the shop manual, but it didn't give much detail and i can't tell if there are one or two at the top, or exactly what is going on.
any help is appreciated, thanks
thanks .. definatly helps.
So it looks to me ... the left upper mounting point also is a mount for the horn. andddddd looking at the picture again i think you may have answered it!
last question i think ... can anyone tell whats going on with the upper right mounting bracket? Is there any bolts? i can't really tell whats all there.
ok well i got the top left hooked up, it shares the same mount as the horn.
as for the right mount, i'm not sure if any screws into it, since theres a hole/mount and on the radiator there is a little dowell type thing that goes into and stablizes it.
Hey man I just put in new spark plugs so i had to remove the radiator. The bolts are a little longer than an inch and fit the 10mm wrench. There should be two of them, one will have a bolt. The other one screws into the bracket itself. I think thats about it, make sure when you remount that you have the radiator bolt holes on the right side of the bike brackets. Good Luck... If you need anymore info PM me.
Ok, when I say on the right side of the brackets I meant the CORRECT side....
The horn mounts on the bottom of the lower tripple clamp with a 12mm bolt.
what? from the pictrure, it shows it sharing the radiator bracket.
Hmmm. It may be that way on the 03-04's. I know for a fact the 05's bolt to the lower triple. I just had my radiator off last week.
1 - 9 of 9 Posts
