Yes rattle...your sensetive like me nobody can find this noise... my post is in this topic you can watch I have the same problem mine says is cct and i cant find manual ape in our country i should but stock cct
Sent from my iPhone using Tapatalk
How many miles is your bike. Usually if it's a ticking sound on the right side it means it's the CCT which can be replaced with a APE one. I'm thinking mine is needing replacing too sadly.
Hello guys i recently bought a 600rr 06.When it gets hot like 95-104 C (im from europe),it start making strange ticking noises from radiator and i think the cct needs a change.So i want you to hear it if you can and tell me my opinion about it.it was a bitty windy so my mic was malfuctioning a bit. https://youtu.be/qtQIGNJ_Lyk one more vid https://youtu.be/Cj3c0QMQMhc
Best to do is use a screwdriver as a stethoscope, put handle on your ear and the point on your cct, rev it and listen. Move the point around to see if the noise gets louder or softer then you will get to the exact location of the noise. But had a cbr1k. Same noise at about 3.5-5k rpm.
