1 - 3 of 3 Posts
3k miles. 1st gear sometimes other gears. Low rpm 2500-3 rattle sound coming from the front. Usually when easing out clutch give it s rev. It would start rattling. Nothing when I'm on stop it high rpm. Just when I'm 1st gear low rpm. All the time on a take off?
I have the same problem, it sounds like there's a screw/nut/bolt or plastic thing bouncing around inside my cluster. It never did any harm to the bikes performance so I left it at that. I hope someone can chip in and give us a solution!
Mine does the same thing. I noticed it stops if you push on the very bottom if the wind screen or on the 3rd eye. Lat time I had it taken apart I tried putting some foam under there but it didn't help.
1 - 3 of 3 Posts
