1 - 2 of 2 Posts
I'm using the RC51 start stop switch on the HRC throttle assembly but when i plug it in it doesn't work and it looks as the plug wires are arranged diffrently. So to anyone that has done the HRC throttle assembly and are using the RC51 start stop switch, how do you bypass this problem?
The wiring is different because the RR takes the start button feed directly from the kill switch but if your RC51 switch is the same as the RVF400 one I used there are 2 separate circuits (i.e. 3 wires on the RR, 4 on the RVF/RC51) I've got mine working but with the race loom so stripped out the un-needed wiring from the switch (brake light wiring and circuit off teh start button that interupts headlights while you press teh starter.. If the colours of the wiring at the 9-pin plug on the RC51 switch match this below I may be able to help further:
Black/RedYellow/RedBlue/WhitetagBlack/Yellow Black Black/WhiteBlack/Green
The colours are taken looking into the end of the switch wiring plug if I remember correctly.
Hope this helps
Troy
1 - 2 of 2 Posts
