1 - 20 of 24 Posts
Stay of the safe side bro order another one
Theyre 10 bucks. Why ask. You wanna find out if its bad? The way you find out is by building up too much oil pressure (due to a blockage in the filter), and it bursting out somewhere you dont want it to. While riding. And then you have the motor running without oil resulting in spun bearings or burned piston rings. Spend the ten bucks lol
Get a new one. Filters are cheap.
guess its a good thing that they have safteys buit into them to stop that ....
but then you have unfiltered oil, and if that happens long enough, see the remainder of your post
but they will not burst
that is btw, the exact reason there is often great debate on if a car filter should be used in the first place... as cars often tend to run lower oil pressure and thus their valving tends to relate to that, where as, if done right, a motorcycle filter would have a higher bypass pressure
which btw, is also why the stock filter uses a true oring, while most car filters use the good ole standard square cut rubber gasket.
QUOTE=msm;3240591]Thats like taking an early morning shower and use the socks from the day before NO NO NO NO![/QUOTE]
Lmao
Sent from my HTC Wildfire S A510e using Motorcycle App
put it this way:
if u have to go through a blood transfusion and there's a option whether to go for new kidneys that are exactly like yours, just made using your cells, brand spanking new, u would settle using "old" kidneys?
haha
1 - 20 of 24 Posts
