1 - 9 of 9 Posts
2009 CBR600RR
The only way to KNOW if you need to adjust your valve lash is to physically measure the clearance according to the service manual. It should be checked and adjusted as needed every 16,000 miles as per manual (07-12).
How many miles on your bike?
· Administrator
I'll give you both sides of the coin; at 17k miles I didn't need to do anything to my shims. I'm now at 30K miles and I'll recheck valve clearances again here soon. No one can really guess how your bike might run if the valve clearances need new shims. If the bike is running fine now then you should be OK for awhile longer. How long? Who knows. Usually you'll see a slow degrade in performance and most of the time its too subtle to even realize. The biggest PITA part of this job was getting the damn valve cover off. It's literally trying to fit a square part through a round frame.
Discussion Starter · #8 ·
Yes, the current condition of the motorcycle is quite satisfactory. Maybe I'll do shim's check at 30,000 miles like you. It was very helpful. Thank you. :D
Since unknown previous owner history.
Do it now for peace of mind?
I've got an 09 w/ about 100K km, needed adjustment on all 3 valve checks so far.
Only a 0.001 (Imperial, not Metric) shim here and there...on various cylinders as time went by.
I don't rev high or ride track.
Mostly canyon riding and high ambient temperatures.
1 - 9 of 9 Posts
