If I'm thinking right it's a 32mm. I've got my socket marked and just grab it when I need it, so if I'm wrong it's cause I haven't looked at the size since I bought it.
32mm is correct, but unless you can find a 6-point 32mm socket (as opposed to a 12-point, which is more common in the larger metric sizes), you'll find that a 1-1/4" socket (which *is* commonly available as a 6-point) will actually fit better.
