okay...heres the deal
i had broken the reatset braket 2 weeks ago....put it back together tonight. then in the process...of switchin brake pedal....and izzle to the new bracket....now the rear break seems to not disenguage......it(the pedal itself) dosnt pop back up liek it would normally
any way to lube this?
also i tightened the bolt that holds the pedal to the bracket pretty tight....mabey loosen it up some.....
but im sure i need to lube it.....what u guys using?
K
lube the pivot? uh, no... you don't lube that but once.
did you "Fix" the old one, or did you buy a whole new assembly?
