1 - 3 of 3 Posts
I didn a search but could not find any info for the problem I am having. I put led rear signals on my bike but did not change the front yet, When i first hooked them up everything was fine both side blinked fast as expected since i did not put the resistor in, Turned the bike off and then later in the day i went to wash it and noticed i did not have any signals or brake light so i replaced the fuse. I can use the brake but if i use the signals they will work but when i tun them off it blows the fuse, i replaced the fuse and put a slightly larger one after the second fuse blew. The left side works sometimes but when i turn on the right side the front light turns off and does not blink. I also notice that the switch for the highbeam is messed up also, so maybe there might be a short inside the switches
G
You probably wired the resistors/signals up wrong and when you use them it's blowing the fuse. Double check your wiring.
1 - 3 of 3 Posts
