I was cleaning up some wiring in the rear of my bike from the previous owner, and after removing his mess of wires i seem to have lost track at which wires are what. I know that the blue wire is the right signal and the orange wire is the left. Also that the 3p connector is for the brake/tail light. But what are the other 2 green wires and the other connector(2p)?
Here is a pic to show what I am asking.
Thanks!
*BOTM Feb '11, Mar '12*
Other green wires are grounds for each signal. There should go into their own 2p connector. I have no idea wtf that other connector is. Their should only be an orange 2p connector (orange wire and ground), blue connector (blue wire and ground) and a black 3p connector ( black wire, black/white wire and ground)
It's your tag light plug... Green is the ground as well on this plug.
O i see so the connectors were cut off then?
And tripage...when I receive that FE from you, will the light from it plug into the tag light plug? or do I just cut the plug off and connect the wires?
Thanks.
No plug on our led light bar, just wires.
