so the other day I rebuilt my master cylinder on my 2011 cbr600rr. the brakes work wonderful, but it notice if you let the bike sit for a couple hours and try to pull the lever for the front brakes; the first pull seems almost sticky, but after that it works normally again. I know I bled the brakes right. has anyone else ever had this problem?
Just curious. Why did you rebuild you MC on a 2011?
did you make sure you put the rubber seals on the piston the same exact way they were on the old one?
Yes it is on my 2011. I bought a genuine honda mc rebuild kit and used motul brake fluid. I took the lever off, regreased all moving parts. I installed the parts exaclty like how it should be. The parts matched my old part
I'm still curious as to why you did. I've seen bikes with over 100k miles that have never had any brake or MC problems.
The why might help us determine what's wrong too.
