1 - 11 of 11 Posts
So my bike (03 RR) hasnt been charging properly lately, and not starting etc. I just went out and took some voltage readings and the battery is at 13.4V @ idle and 13.2V @ 5,000 RPMs. The battery is about a month old so its probably not the battery. Im not sure why the voltage drops as I rev but I double/triple checked and the readings are correct.
Can anyone help by telling me if these reading mean I need a new Voltage Regualtor/Rectifier?
thanks
k thanks, i ordered an 06 rectifier from the marketplace here, ill let you guys know what happens when i get it
ok so i installed the new rectifier and changed the battery yet still the same issue. when i put the bike away after riding for a while the battery is generally around 11.6-12 V. and at idle its around 13.6 and at 5000 rpms it drops to 12.6. I also noticed that when the bike is idling in neutral with the high beam on, the neural light will flicker along with the headlights. but when i turn off the highbeam then it stops flickering. I have HIDs, so is it possible that the HID's can be causing this? however ive had HID's for 2 years and am just noticing this now. or is it the stator?
thanks
hmmm, maybe ur generator. if you know someone who can take reading of the whole charging system you can narrow your problem. check your wire harness for any corrosion, just make sure everything is clean
ok so for the last couple of days ive been riding around with the high beam off, and this seems to help fix the problem. now when i park the bike after riding the battery is at 12.6V and a few hours later drops to 12.2 and holds steady there.
However the thing is that ive been riding with my highbeam on (HID's) all the time for the past 2 years and had no issues so why all of a sudden its causing issues now? even though i have a brand new battery
thanks
Oh man, I had so many problems with the charging system on my 03. I bought a new battery, swapped out the rectifier and regulator from an 05 and it still didnt fix it. The dealership said Id have to pull my "flywheel" and replace the entire charging system. probably around 600-800 bucks.
I said F%^& that and bought a battery tender, just plugged it in after every ride and it would be good to go for the day (unless it was hot out, haha)
checked wiring harness, no corrosion; what readings do i need to take?
Firstly please note NEVER start the bike then disconnect the battery - you will likely blow something up
First off disconnect the battery negative terminal and then check its voltage. Should be ~13VDC when fully charged, if its under 12.4VDC then hook it up to a battery charger until fully charged then re-test, if still below 12.4VDC then take it in to a shop and get it load tested.
Reconnect the negative terminal and start the bike. Now check the DC voltage at around 5,000 rpm with the high beam on, should be ~14.2VDC but below 15.5VDC.
If below 13.5VDC then read on. If above 15.5VDC then you probably need another regulator and a new battery. (worth getting it checked by a shop at this point cause batteries and regs aint cheap)
So, if you have less than 13.5VDC with the bike running you are not charging the battery properly hence you cant start, pull off the left hand side mid fairing under that you will find a plug with 3 yellow wires in it, disconnect it and check the resistance between those wires, it should be between 0.1 Ohms and 1.0 Ohm If its not then you need a new alternator (generator). If it is then you likely need a new regulator.
Other things to check before handing out money:
Check the AC voltage coming out of the regulator with the bike running, should be under 1VAC. If its not then new regulator.
With the ignition key in the OFF or LOCKED position then disconnect the negative terminal from the battery and place an ammeter between the negative terminal of the battery and the negative wire. This will allow you measure your leakage current which should be no more than 2mA, if its is then you need to disconnect the regulator and re-check. If its still over 2mA then your problem is most likely with the ignition switch otherwise - new regulator.
Hope all this helps and makes sense. I'm happy to clarify any points you are a little unsure on.
1 - 11 of 11 Posts
