1 - 1 of 1 Posts
question 1: How much play should there be in the clutch lifter pin ?
I can slide mine in and out about 1/2 cm.
I can't seem to get the case cover on - everytime I try, the pin gets pushed in a bit and I can't grab it with the clutch lever. I'm wondering if I put the clutch in wrong or if there is just a trick to putting it back on. I know you're supposed to install while turning the clutch lever clockwise to grab the pin, but it either gets caught on it, and the rest of the cover won't seat properly, or the pin gets pushed in and it just grabs air.. any advise on this would be most helpful.
thanks !
('03 600rr)
1 - 1 of 1 Posts
