1 - 17 of 17 Posts
I have searched and couldnt find a thread or write up/how to
If anyone could help me out on this one I would appreciate it.
its an 03 with 4600 miles and sat for a while, injector or two are gummed up below 5k rpm and wanna get them cleaned!
thanks!
run a bottle of motul fuel system cleaner (or similar) through it with a fresh tank of fuel. do it twice if you feel its required
i have run seafoam through it twice, and gumout full system cleaner through it today and i felt it has helped the most... but still not perfect
i have put 1100 miles on it since last month when i bought it
Chattanooga, TN
there isnt any close that im aware of, but i know there are a few sponsors on here that do it, and I dont mind shipping them off.
I took all the fairings off when i got it to paint, and replaced air filter, oil, and spark plugs when I got it. Just wanted to see how to remove the injectors so i can send them off and get tested
I can look out my service manual & post up a step by step to removing the injectors, but I can't do it right now if you're in a rush
no rush, if its in the service manual i should be able to get a .pdf on the internet somewhere right?
I imagine you will find a pdf somewhere but I don't know where. or you could buy the service manual, they are a fantastic resource to have, it's saved me a lot of money over the years.
but I can do a write up on injector removal if you need it, let me know.
If doing one wouldnt take long that would be awesome!!! I tried looking for a .pdf of a manual and couldnt find one, and my buddy that also has an 03 didnt have his manual either.
You dont have to if it will be a ton of work though
If you do, just tell me what to do once the tank cover is off, as far as removing the entire air box assembly and how to handle the injectors etc.. that would be awesome!
Discussion Starter #11
once you get to the lower fuel rail, you just unplug them and pull them out?
So i got a manual from here:
http://www.mediafire.com/?1avwcwlsz8gpsnx#!
and it says secondary injectors open at 5500rpm
5500 and under seems to be where my problem is..
and if i drive at 6k or above or stay higher rpm at 75% throttle and above then starting off is real smooth.... but if its always between 1-5k around in the city then it gets worse and sucks to drive and jerky and looses a lot of power..
so im thinking its my primarys are in bad bad shape...
big thanks!
Will be taking them somewhere tomorrow to get taken care of!
glad you got it sorted, let us know if having them done professionally helps
Will do!
it only had 4000 miles on it, and being a 10 year old bike and it was never rode hard... im sure they are gummed up horribly and thats my problem
any mods I can do since i have it torn down this far?
spray some cleaner on the intake valves that have carbon i can see on them :p
there's a few but it depends on your needs.
PAIR valve delete
velocity stacks
performance air filter
gut the air intake
these are just what you CAN do, but you should read up on them for the pros & cons before doing any of them because there's a lot of conflicting opinions on each
Discussion Starter #17
now im having this problem.
http://www.600rr.net/vb/showthread.php?t=333338
any idea from the guys that have been helping me? would appreciate it greatly!
trying to take the bike on a 4 hour trip tomorrow to montgomery, al to see family.. better MPG than my truck and my truck needs some work before i take a trip that long
1 - 17 of 17 Posts
