That's what I was thinking. And I can just bolt it back when I'm done? Nothing has to be alighned or anything after removing it?JSS829 said:just take off the top triple....everything will stay in place
as long as you don't loosen the bolts on the bottom triple clamp that hold the forks everything will stay in place.YZ3 said:That's what I was thinking. And I can just bolt it back when I'm done? Nothing has to be alighned or anything after removing it?
uhh..thats NOT the easiest way, in fact its the slowest most inefficient way. Like others said before, just remove the upper triple and swap out the clipon. No need to remove wheels, forks, ...silver05 said:The easiest way would be to remove the front wheel, and slide the right side fork down. All you have to do is loosen the pincher bolts for the right side fork, and also the clamp for the clipon. Slide the fork down just past the upper clamp, enought to replace the old clipon and replace it with the new one. Slide the fork back up, and make sure that it is aligned with the left side fork. Tighten all bolts, and replace the wheel.
You need a front stand that lifts from the steering stem.
+1 Fastest and easiest way.99SH said:uhh..thats NOT the easiest way, in fact its the slowest most inefficient way. Like others said before, just remove the upper triple and swap out the clipon. No need to remove wheels, forks, ...
+1, I think that IS the easiest way.99SH said:uhh..thats NOT the easiest way, in fact its the slowest most inefficient way. Like others said before, just remove the upper triple and swap out the clipon. No need to remove wheels, forks, ...
Did a search which yield'd 30 minutes of nothing. If the middle bolt requires a 30mm socket then what size wrench is need to turn the top of the shocks?99SH said:I think it was a 30mm, do a search you'll get ur answer quick.
BiGxbOix510 said:+1, I think that IS the easiest way.
Put the front wheel against a wall and in gear for the rear.
I remember the first time I took the triple off, the steering stem slid down a little, I almost pooped my pants.
Yea, I met the forks my bad. It's not about being more clear it's about getting the part terms correct.99SH said:Search for "steering stem nut", you'll get many many hits.
I dont understand what nut you're talking about the shocks?? be more clear. Do you mean forks?
Tell that to PETERVERDONEDESIGNS.COM it was his pic, haha.NewRedRider said:![]()
Holy crap put some rags in those throttle bodies man! I'd hate to hear someone wadded a motor from a $0.50 screw.
