Ok I'm replacing my coolant over-fill bottle on my 2005 honda 600RR and was wondering, should I bleed the coolant afterwards? I called 2 different dealerships and asked the service department and they both said just swap them out and your good to go. I'm thinking the only time you should bleed the coolant is if you crack open the thermostat or water pump and air gets in that way? ok thanks for all the help!
Resident Leg-Humper Females Beware
yeah listen to the techs and just swap em then put some coolant back into the new one.
2+ on swapping and filling it up again. No need to drain the system.
That sounds right. Their techs I'd listen to them
