I downed my bike =( It was a couple nights ago and I was making a left hand turn only going about 15mph and I didn't see this fresh patch of mud on the road and ran right over it and BAM down went me and the bike. Anyways, I'm replacing the swingarm because the part where you can screw in a spool for the swingarm is damaged and I don't want to have to weld one on. My question is, other than new bearings, what else should I replace when switching out the swing arm? I talked to one dealership and they said just the bearings. The other dealership said I should replace anything rubber like maybe the dust seals and whatever? Is that true? I was thinking just the bearings would be fine. Ok thanks for the help.
keep in mind this is a 2005 with only 1500 miles on her. Just picked her up one month ago. Sucks I dropped her and its one of those drops where it didn't even have to happen...oh well.
so in the pic...what should i replace? the bearings are number 22 but it also says that 8 and 9 or "needle bearings" so should I be replacing those too?
1: CHAIN SET, DRIVE
(DID525HV-112L-120L) (DAIDO)
184605-001
$140.37
1: CHAIN SET, DRIVE
(112L-120L) (RK EXCEL)
184606-001
$131.05
2: CASE, DRIVE CHAIN
3862412-001
$33.75
3: MASTER LINK SET
(DAIDO)
149130-001
$5.47
3: MASTER LINK SET
(RK EXCEL)
149131-001
$5.47
4: COLLAR, L. RR. AXLE
3863479-001
$19.53
5: COLLAR, R. RR. AXLE
3863487-001
$15.98
6: BOLT, SWINGARM PIVOT
3873411-001
$27.36
7: NUT, SWINGARM PIVOT
1472700-001
$10.51
8: COLLAR, R.
3873548-001
$16.27
9: COLLAR, L.
3873550-001
$16.27
10: SLIDER, CHAIN
3873657-001
$19.96
11: SWINGARM SUB, RR.
3873686-001
$708.45
12: COLLAR
97647-001
$2.16
13: MARK, UNIT PROLINK
1989566-001
$2.40
14: BOLT, FLANGE (6X18)
(6X18)
232992-001
$1.80
15: BOLT, HEX. (8X50)
(8X50)
935404-001
$1.53
16: BOLT, FLANGE (6MM)
(6MM)
233798-001
$1.87
17: BOLT, FLANGE (6X14)
234980-001
18: NUT, HEX. (8MM)
(8MM)
236816-001
19: WASHER (6MM)
(6MM)
238689-001
20: BEARING, NEEDLE
935546-001
21: BEARING, NEEDLE
242426-001
22: BEARING (20X37X9)
(20X37X9)
242436-001
23: DUST SEAL (28X37X4)
(28X37X4)
242839-001
24: DUST SEAL (26X37X5)
(26X37X5)
243138-001
25: DUST SEAL (28X34X4)
(28X34X4)
935567-001
26: CIRCLIP (37MM)
(INNER) (37MM)
249679-001
