1 - 3 of 3 Posts
Hey does anyone no the way the upper fairing comes off?
I was putting on my flush mount lights and the wire from the light to the harness came undone!!!! Don't ask I guess it was not clipped tight at the harness... I tried for about 20min and could not access that area!
Help!!!
i love juggggggggzzz
you want to take the whole nose off? remove the 3 hex bolts on each side of the nose, the 2 mirror bolts, then theres some plastic screws underneath surrounding the edges you need to remove some of them cant remember exactly which ones. then pull forward. you need to then remove the plug in the back of the gauges.
Hey, thanks but I got it! You only need to remove 2 screws under the nose and the 3 on then side. the pull it off. Thanks
1 - 3 of 3 Posts
