Hi guys,
Sometimes My right signal works, and don't working sometimes... i'm not sure why? i check all the wirings and it's fine. I have those ebay aftermarket ones... but the left one works perfectly, only the right side. any ideas?
relay? flashers?
please let me know...
i have change the rear bulbs and test the signal lights everything is working... anyone knows where the signal flashers are located?
Is it only the front or only the rear or both?
And does it do it on the left hand side or only the right?
Your flasher relay will affect all of your indicators, and its under the seat.
both rear and front.. left side only.. the right side works fine.. even if the left side stop working..., i might buy a new electronic flasher relay
Should be your indicator switch or wiring from the front harness.
