1 - 10 of 10 Posts
Quick history I've got a Bazzazz FI installed, but that's about the extent of my fueling related mods. The bike ran great for weeks after that installation, and then all of a sudden one day began vibrating badly and has been ever since, along with rough idling and nearly dying at warm up (but hasn't yet), and when riding there's almost no throttle response where before cracking the throttle a little the bike would take off. Though the bike still makes power at high rpm and throttle, and can lift the front wheel in first or second. This makes me think it's something idle-related like an IACV issue? So far I've replaced the plugs (just yesterday), checked all connections where I had to plug in the Bazzazz inline (injectors and sensors), lifted the tank out while running the bike to see if there was a pinched fuel line, and nothing has helped.
So I've run out of ideas short of the IACV. Is there a way to test that it's not the problem? The service manual doesn't explain it all except to take it out and see if it moves. That doesn't really help, obviously it works somewhat or else the bike wouldn't run. What is it that controls the IACV, the MAP sensor?
Anyways, I'm pretty bummed I was hoping replacing the plugs would do the trick, and don't know what to try next.
Well here's the weird thing. I actually rode it to work this morning after changing the plugs ,and the vibration went way down, and sounded and ran great. But then by the time I got home from work now everything's gone to **** again?
I will, I've just been hoping it wouldn't come to that
Coil packs are all good? Just something else to check. See if any of your headers are not hot after the bike has started. If not that, I would look at the last thing you did. Bazzaz seems like the only other option. T
So no, I haven't had time to pull the bazzaz out and run all the wires stock again. But here's the strangest thing is that it seems almost random how well/not well the bike runs every time I start it up. I'm still missing some of the low end/midrange power and the cold-start idle is still rough no matter what, but as far as serious vibration and in general running much worse...it seems to happen maybe only 1/4 times I start it up, and will continue that way until I stop the bike and start it again the next morning, when most likely it will be more ok again.
It's confusing the hell out of me but again I can't say much else until I try removing the Bazzaz.
Thanks for the tips trip, is there a way to directly test the coils? The plugs I pulled all looked almost textbook good, and the headers all get too hot to touch only a few seconds after starting up.
You know I've been following this thread http://www.600rr.net/vb/showthread.php?t=108269
and a few guys there seem to have very similar issues...
1 - 10 of 10 Posts
