When I bought my 03 rr the rt frame slider was torn off from a previous wreck. Here is my problem. There is about a 3/4 inch gap between the frame and the engine where the rt slider should bolt. Also there is nothing threaded for it to bolt to. What is suposed to be between the frame and engine? Also where are the threads suposed to be?
Check an OEM parts schematic on Bikebandit, but I believe that there's supposed to be a spacer in there. Its just a small, tubelike piece of aluminum that fills the gap.
it should bolt into the engine. at least thats how my 07 is. it has the same gap and a silver aluminum spacer. there is a long bolt that threads into the block of the engine. my frame sliders replaced the spacer with a mount.
