1 - 9 of 9 Posts
I was gone for some time and now my tank is rusted...I know, I shoulda done this or that, I guess I learned the hard way.
I was told that I would have to replace the tank since after I started the bike, rust got into the lines and it is clogged. It runs but when I tried to get the rpms up the bike just bogs down for obvious reasons. It seems like there is no problem with it when the rpms are below 8k.
I talked to the dealer and they said it would cost me $1000 to replace the tank and clean everything. Is there another alternative?
there are etching kits you can buy but they can cause more problems then rust if the coating doesn't stick well ....
you can get a used tank on ebay or some forum like this one for pretty cheap and if your bike is carbed you can get the carbs cleaned for a few hours labor at any dealership but if it's injected you may just want to get another fuel pump ...
All RR's are FI.
As suggested, I'd probably just pick up another tank on ebay. You'll save yourself a lot of headache in the long run.
Alright, I am getting a fuel pump and gas tank off of ebay for $60 each. What else needs to be done besides replacing those parts? Do I have to flush the fuel system to clean everything else out? I am not really a gear head so any help is appreciated.
you can get the inside of tanks sand blasted
Bad idea to ever sandblast inside a tank. Impossible to ever get all the media out. There are places that specialize in repairing fuel tanks. Tank renew is one. I don't know if they are nationwide or not. They chemically clean the inside of a tank and then recoat it. About 120 to 150 bucks for a car tank, I think a bike tank would be much less. I think you found the right answer with used stuff. This is why you should store the bike with a full tank of fuel.
You can clean and re-coat a tank if you don't have the funds for a replacement tank. I've used Kreem and it's about $30 for the kit.
As far as getting it running again, I would put in the replacement tank and pump, change the spark plugs, and see if it cranks up. If not, consider invesigating the rest of the fuel system, injectors, etc.
1 - 9 of 9 Posts
