proper sand blasting takes ALOT of airflow, my brother has a huge air compressor and its only barely big enough to keep up. That little 40$ ebay special is a waste of time, you would get 8 seconds of sand blasting in and then have to wait 10 mins for it to fill back up again.
Your best bet would be to put up a post on your local craigslist or search for listings for sandblasting services, alot of times there are weekend warriors with the equipment that will do it for very cheap.
Edit - just noticed that the eBay special is just basically the hopper and hose. If you have access to a large enough air compressor then it would likely do the job.
i have a large industrial aircompressor and my blaster treats it like a little bitch when i use it like everyone else said take it somewhere have it blasted
