are the bulbs removable? if so, how do u do it? i opened up the plastic but couldn't twist or pull on the bulb. something like this...
I tried and figured I could break the bulb to get it out but getting in a new one was going to be a challenge. I gave up and bought some new ones since they like $10 and I wanted a change in style anyway.
X
Get Jiggy with it
jdmbuilt said:
u can't twist it out, right?
I have the 3'd one on the left (smoked) YES you can replace the bulbs and yes they do twist out just like any other bulb the only difference is that they are so small and there is very little space so it does take a little patience and some small needle nose pliers. just take your time and you can change them out without a problem.....it's harder getting them in then it is taking them out though....
damn, sounds like a lot of work. are they the types of bulbs that u gotta press down and twist? or just twist?
Get Jiggy with it
I just replaced one in the back and yeah its a little work........... yes you do have to push and turn.
